1978 ford f150 box
  • 4
Eliveldman1
14
Michigan
so i got my grandpas 1978 ford f150 custom(extended cab) and i want to put a stereo system in that will make people juice and i have the money to spend just nothing to crazy like above 800 cause my parents prob wouldn't approve
so i need a box design that will take up the back bench seat, i have a 5ft by 1ft 9in space to work with
i also have 2 skar ix 12s and a rp 350 that i got for xmas that i know wont even pack any bass
so if you have any suggestions for 2 twelve in subs and a amp please let me know
i also need a alt that will give enough power and no have my headlights dim, and again price really isnt an issue just nothing crazy
3G 130 amp alternator swap is pretty easy. Plenty in the junk yard for cheap. I did this swap with my 86 when I put a subwoofer in it. Make sure to upgrade the power and grounds as well. AKA big 3.
I have a 96 f150 with the 95 amp alternator. What vehicles would have this 3G 130 amp alternator for a swap?
A 96 would be a T mount like my 94 was so you can get a 130 from a
93-96 V8 Econoline
97-03 V6 Econoline E-Series or F-150
95-01 4.0 V6 Explorer or Ranger
The large case 130 amps have 2 holes in the front and the small case 95s have 4.
354
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
Eliveldman1
Eliveldman1
Michigan
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
