Bat Terminals.
  • 6
What are all of you using for battery terminals? i need one with atleast 1/0(or bigger) input, 1(4awg), and one or two for factory small wiring.
man i have some great knu terminals, they great because they're "low profile" and have covers but omg they a pain to take off.. the screws are on the bottom so u have to stick all wires in it tighten them then mount it onto battery and the allen screw is very low on side each one takes me about 5 mins to get off be cause it's so close to other stuff.. anyway i'll show u those in case u have tons of room around your battery, if not get some gp audio 4 or 6 spot terminals others similar to those everywhere.. this is before i added big 3 wires
You don't need an ISO unless you play a lot with the car off. With the car running the ISO is bypassed. Toolmaker for terminals
if i got a 2nd battery, itd be a diff size/age and id be worried about voltage differences pulling between each other.
I use a butane torch for thick 4-8 gauge wire. For those you could just get ring type crimp connectors. 10-12 gauge is pretty easy to solder with...
20
179
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
656
The way it is sitting doesn't seem unsound, just not neat and factory looking. You might be able to come 90 degrees out the side cut away some...
14
Im really glad I found this site, you've all taken time to help me out, much appreciated!!! I got a ported kicker brand box and 2 of those 12 sub...
A quick Google search, and I found this option. https://www.amazon.com/dp/B004QCBM28/?tag=caraudiocom-20
The Camry
Hey, I Try.
The Camry
Western Oregon
Chris McNeeley
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
