Rockford Fosgate 12" Power DVC D4
  • 2
Bburchett1
1 - 12" Rockford Fosgate Power DVC
Works perfectly. Cosmetically just has some very minor wear on the motor as pictured. Does not affect the performance or sound of the speaker. Super stiff still.
This thing gets down!
Cosmetic: 8/10
Mechanical: 10/10
Sensitivity: 87 dB
RMS Power Range : 1000 Watts
Peak Power Handling: 2000 Watts
Impedance: Dual 4 Ohm
Low Frequency response: 24 Hz
High Frequency Response: 200 Hz
Diameter: 12 Inch
$200/obo plus actual shipping (around $28-$45)
FedEx will be $28-$55 depending on your location
Willing to ship via USPS or UPS upon request.
I just want to thank you for actually following the classified rules and posting pictures with your username and date. You are in the 1% of noobs that can read and comprehend. Glws!
I used to be a moderator on another site so I know to read the rules before posting.
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
After looking at amazon for kicker q product details, it showed rms of 1200@2ohm If you’re at 2ohm you’re not feeding it enough power. At 1ohm...
Bburchett1
Bburchett1
Chaska, MN
Bburchett1
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
