Tweeter placement
  • 5
double sided tape.
if its those ct-2 tweeters, put them into the mounting kits and put one screw on just to hold it in place, you dont even have to run wire through the door yet... just test it out. See which way sounds best.
double sided tape.
Stick Velcro. My savior.
im thinking the a pillars. they dont move when the door opens LoL
its different with every car, dont shoot yourself in the foot by just relegating to that option without even testing the sail panel.
Get double sided tape and test every location possible. This is an extremely important step that you cant fk up with IMHO.
very fair point. ill take your advice sir! also, i knew there was a name for that little triangle of plastic, just couldnt think of it LoL
A pillar is better ..closer to equal wave path lengths
that was my thought too. but ill give them both a shot with the double sided tape
Don’t just try different spots. Try different axis. That’s more important. Pillars also have a lot of dash reflections. Lay towels on the dash.
literally what made my tweeters sound crappy when I tried them on the A pillars. Nasty peaks left and right. I get zero with sail panels. His tweeter mounting kit has adjustable axis swivel.
This type is made as a base that would need work for a finished product. When you look it up in eBay, you will get other recommendations that may...
105
Tons of options in that budget, including the cost of installation,
10
594
It'll look like a "Hawaiian professional" did your install then 🤣
17
No problem. I think alot of the issues I see on here are people aren't differentiating between AC (music) and DC voltage.
15
youdoofus
Skibidi
youdoofus
planet earth
Louisiana_CRX
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
