Kicker zx2500 or kx2500 $$ wanted
251
859
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Deboelduro
Deboelduro
Hartford ct
BassAddictJ
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
