Mounting Subwoofer
  • 6
i use some coated screws, but with reg philips heads. use them to mount my amp too. shorted than these tho...
yeah i normally use drywall screws. i used #12 1 1/4" wood screw this time., tad bigger (not as long) since had to take sub outta box few times.. if u have double baffle box (i assume u pre drill small hole 1st anyway) u can use 2" screws. just don't go to skinny on the size..
I like these deck screws with the torx drive myself. Drywall screws are OK for smaller subs but much more prone to breaking and IMO the torx is a bit less likely to slip or strip.
I’ve installed a lot of brand new subs before. Like we’d build boxes and install the new sub into the box, and then install the box and tune the...
23
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
AnthonyO
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
