RCA plugs on a Bridged 4 ch amp.
Hello
This may sound as a dumb question but, On a 4 ch amp that you are going to bridge into 2 ch, do you have to have all 4 RCA plugs plugged into the amp ? Or are only 2 ch RCA from the sub output from the HU ok. And where would you plug the 2 sub channels from HU into what RCA ports on 4 ch.
I have the Pioneer HU that has 6 ch output with the 2 sub output RCA cables ran into a Y adapter so to use all 4 RCA inputs on the amp in a 2 ch bridged mode. It sounds good so, is there a wrong or a right way to do it on RCA's. I understand how to wire the output speakers into a 2 ch bridged mode but i have never read or see any listing of the RCA side of a bridged 4 ch amp on the proper way to do it.
Thanks
It depends on the amp, some amps have a switch for 2 or 4 channel input, others require Y adapters, that info should be in the manual.
It did not say in manual if all 4 RCA had to be used. But it only said about bridging to 2 ch the speaker wires. The Kenwood XR400-4 amp So that is why i am asking the question. I did install the amp with the Y adapters to all 4 ch
the subs sound ok though and don't seam to have any issues.
It did not say in manual if all 4 RCA had to be used. But it only said about bridging to 2 ch the speaker wires. The Kenwood XR400-4 amp So that is why i am asking the question. I did install the amp with the Y adapters to all 4 chthe subs sound ok though and don't seam to have any issues.
That amp has a switch, set the "Input Sel." switch to "A" then you only use "Line In A" no Y's needed.
oh ok i saw that switch but it did not specify that what it was for. But for now i have it set to A/B and using a Y adapter and 4ch. Will that hurt it ? Personally i don't think so but let me know if i'm wrong.
Bass sounds good though. I just may have to reach under seat and fix it to A switch and plug only 2 RCA in.
Thanks
Do you have 4 rca already ran? Just plug them all in like normal then switch to bridged if that’s what that switch is. The amp should pull whatever signal it needs with all 4 rca connected..
yes i already have the 4 ch with Y adapters plugged in. I have it set up with the R rca set to R side of amp and L rca set to L side of amp. So if there is a portion of a song they will go from side to side like R to L the subs will make it so. There has been many rock songs that have one channel of song then the other channel kicks in. Allen Parson Project has a few songs like that the move from side to side in the songs and everything matches. I have heard rock drum solos that do the same. So when many installers say just use a mono sub amp or a single channel on a 2 ch amp, they miss out on the songs that were recorded with any of the sound moving from left to right. One song that comes to mind is
Van Halen - Everybody Wants Some!! the drum intro moves left to right. You can really hear it pronounced in a pair of headphones. but, in my car sound system it you can also hear it move L to R. This is how the Artist intended for it to be heard. I know you pro installers out there know what I'm talking about. Some have commented to me that i should just install a mono sub amp in my system and wire to 2 ohm. but NO WAY. that just me. I respect all own tastes.
But everyone has there own taste on music. Thanks
No make or model number on it? Do you have an exact picture of the rear and all its glory?
474
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
435
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
411
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
644
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
744
stephgirl
stephgirl
Covina CA
stephgirl
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
