Active Vs Passive Power Required For Comps
giltyler
In the past I always ran passive crossovers that came with the components and in the really old days caps and coils to do the filtering.
Now I want to try Active and want to know what Power output I need since the network will not be wasting power.
Will a small 4 channel Hertz or Audison be enough 60x4
Components will be higher end mainstream or basics from hertz Audison etc
Ram 2500 front door and dash location
The extra power comes in handy when dealing with the reactive nature of all the different components in the passive crossover, combined with the reactive nature of the drivers. They can pose difficult loads to the amplifier because of the multiple inductive and capacitive phase angles and the cost of that is a looser "grip" on the driver itself. A few watts will make most drivers sing, all the extra power goes mostly into controlling the circuit/drivers during the wildly varying waveforms and amplitudes that music is composed of. So you need a few watts to get going and a few more to get going louder, all the while having tens to hundreds on tap for the necessary dynamics. You basically have a direct grip on the driver in an active scenario, and this offers better control.
Active. You can use the point and slope that fits your install. You can have more tuning ability in the tweeters intensity.
Timing if it’s greatly different.
Passive. You can’t do any of that.
Power is not the deciding factor, it’s no factor.
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
728
10
839
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
949
As for your setup, the circled input in that reply is where the LOC (built into the amp) is located. You don’t need a LOC other than that. All you...
35
4K
Your deck has it built in ...you just need to dial it in ...i have 2 or 3 of those decks ...nice for the money
giltyler
giltyler
DFW METROPLEX
LosIsATool
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
