distibution block & crossover?
  • 4
sehana
Vehicle: 2008 Ford Fusion 2.3 4cyl
Unit: Boss BV960NV
Amp: 1x Alpine MRV-F300
Speakers: 4x Rockford Fosgate Prime R168X2
Accessories: Rockford Fosgate RFK8i
1. Trying to find out if I need a distribution block?
2. Forgot I had tweeters, do I still need a crossover for the front speakers and tweeters?
3. Will the crossover divide power between the front speakers and tweeters?
Thank you for the help!
Vehicle: 2008 Ford Fusion 2.3 4cylUnit: Boss BV960NV
1. If you have 1 amp, you do not need a distrubution block. That Alpine has a built in fuse, so you don't need a fuse block either.
2. No, that speaker appears to have a built in Tweeter with internal crossover.
3. In the most extreme cases, the crossover sends 100 watts from a 100 watt amp to the woofer and 0 to the tweet, or 100 to the tweet and 0 to the woofer. But you don't need to worry about it since it's built in.
I really appreciate all the info and help! Guess I should have read that the speakers said integrated crossover
To members using an ad blocker, I want you to know that this site is not free to maintain. It requires substantial monthly ad revenue to keep it...
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
577
Buy the 4 ch and keep the other. Usually on a 5 ch there isnt much of a substage, but there are a couple with a 1k @1ohm ch., but very few. A 5...
Just ignore Red...he's wealth of useless to dangerous advice...all without knowing what he's talking about
19
3K
sehana
sehana
Arizona
sehana
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
