Humming/Buzzing Noise
  • 2
kwatson30
I have a JL 500/1 amp w/ 15" Eclipse sub. Everything was working fine when I went into a store. When I returned and turned my car on, I immediately heard a loud Humming/buzzing noise coming from my back left speaker and sub. I immediately turned off the radio, but it didn't stop the noise.
I then unhooked the back left speaker to stop the noise, and had to unhook the RCAs to the amp to stop the noise from the sub. When I reconnect the speaker and RCAs, the noise starts again and no music will play out of the particular speakers, and no bass comes out of the sub. All other speakers work fine... any idea what the issue is?
Problem should be either your RCAs shorting out to ground or an internal fault with your head unit... replace RCAs to test. Be VERY careful, that sort of "noise" can burn up speakers fast and that is not good for your amp. I'd be testing with a speaker you don't care about and be ready to power off the amp quick if the noise persists.
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Just when you think you're humming along... and... hmmmm happens!
22
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
kwatson30
kwatson30
Illinois
hispls
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
