Power
HO Alt, 1/0 OFC welding cable, and replace your current battery (provided it's not tiny) with an AGM and you should be fine
I have a 160 Alt...I don't need an alt. I just need an extra battery. I'l just get a 700CA battery. I Have 0 gauge power and ground. I'm just adding as a precautionary measure.
You didn't mention the alt. Probably getting around 80a at idle so you should be ok especially with 1200w. 2-3kw is where I see people needing more upgrades
Shouldn’t need anything. If you have issues it’s you not the electrical. Clipping or bad ground.
My thoughs as well. A solid primary battery and "big 3" should be adequate to support that assuming your factory alternator is functioning.
Wtf?! moron. And this is coming from someone who can't build a wall.
Cars don't need batteries these day bro. They run off of electricity.
No sweat. I was also going to suggest New England Providore (NEP Audio) but it looks like they shut down the shop.
68
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
136
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
144
443
With 6500 rms.. you are still going to need some battery bank and/or supply for that demand
15
SQBeast
SQBeast
Leesburg, Ga
nauc
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
