Power
HO Alt, 1/0 OFC welding cable, and replace your current battery (provided it's not tiny) with an AGM and you should be fine
I have a 160 Alt...I don't need an alt. I just need an extra battery. I'l just get a 700CA battery. I Have 0 gauge power and ground. I'm just adding as a precautionary measure.
You didn't mention the alt. Probably getting around 80a at idle so you should be ok especially with 1200w. 2-3kw is where I see people needing more upgrades
Shouldn’t need anything. If you have issues it’s you not the electrical. Clipping or bad ground.
My thoughs as well. A solid primary battery and "big 3" should be adequate to support that assuming your factory alternator is functioning.
Wtf?! moron. And this is coming from someone who can't build a wall.
Cars don't need batteries these day bro. They run off of electricity.
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
378
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
296
638
With 6500 rms.. you are still going to need some battery bank and/or supply for that demand
17
SQBeast
SQBeast
Leesburg, Ga
nauc
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
