Jump to content
Sign in to follow this
TheOCSurfer
Need Help. Wanted 5 Channel Compact AMP
Recommended Posts
#1 post
History I use to be on top of this stuff, but I've been out of the stereo mods for quite a few years. I know the amps have gotten much smaller and efficient since my glory days. Now I have no idea whats out there. I use to have only Alpine products.
Going into a 2008 6.4 Ford F250 Superduty, Crew Cab. I'd like to squeeze it into my dash behind my Sony HeadUnit. Needs to be under $350.00. I plan on new speakers in the doors and a single or dual sub behind the rear seats.
Thanks for your input
TheOCSurfer
Share this post
Link to post
Share on other sites
you're not going to find a 5 channel small enough to put behind a headunit.... and an amp needs to be "mounted".
need to install under seat or behind rear seat.
2004 Honda S2000
Pioneer DEH-80-PRS
new build in progress (most likely audison voce av k6, tc sounds tc-1000 8, phoenix gold ti21600.5
Share this post
Link to post
OKAY, how about this one 179.00 Soundstream T5.2500DL
Share this post
Link to post
if you're looking to stay around $200 i would go with the pioneer gm-d9605.
the kenwood x801-5 is quite small and the xr900-5 is nice as well.
but for around $300-400 i would look at the zapco st-5x or sundown sae 1100.5, something along those lines if you're not worried about the size of the amp.
2004 Honda S2000
Pioneer DEH-80-PRS
Share this post
Link to post
Yeah no way in hell an amp is going behind the dash....not only a lot of work but too much wires behind there and more than likely not enough space for one, not to mention if could easily overheat and shut it down.
NVX or PPI 5 ch might work for ya.
97 4 dr. Tahoe
Interstate battery
Alpine 9835
Polk Audio MM6501 comps
Wolfram amps coming soon, 3000.1, 125.4
2 Sundown Audio X 15's Tuned @ 30Hz.
Knukonceptz/Royal Excelene wiring
Share this post
Link to post
#1 post
TheOCSurfer
Zed Audio has a very small 4 channel and 1 channel amp but I think with any of those super tiny amps, while mounting footprint isn't big you still need to consider proper air flow/cooling. I don't think any amp would do well buried up in the dash. You should have a fair bit of space in the back of that either on the back wall or on the floor by the back wall for some small amp(s) (pic related)
Do avoid soundstream. It's bottom of the barrel flea market junk.
Share this post
Link to post
The Phoenix gold sx1200.5 is a solid amp as well.
2004 Honda S2000
Pioneer DEH-80-PRS
Share this post
Link to post
5 Mosconi pico amps.
2014 Ford Fusion SE 2.0T
JBL MS-8
Zapco ST-4X SQ, ST-1000XMii
IDQ12v4 1.8cu sealed
Alpine SPX Pro ring radiators
Hertz HV165XL
Knuconceptz OFC, Custom fit Soundrive RCAs.
Share this post
Link to post
He said under $350 for a 5 channel...
2004 Honda S2000
Pioneer DEH-80-PRS
Share this post
Link to post
LOTS of options for you.
As already mentioned the pioneer 9605 is a decent amp,
Here are ones I think are up to the job.
NVX JAD900.5 and it's clones (Polk PAD5000.5, PPI 900.5)
Infinity Kappa K5 ($299 @ Crutchfield)
DS18 Candy X5B
Audiotec Fischer Helix Dark Blue 5
Rockville DB55
Head Unit: Pioneer Avic-5201NEX
Amplifiers: Orion XTR1000.4, Alphard DB-2000.1D
Front Speakers: Infinity Perfect 600 Components
Rear Speakers: Image Dynamics ID6.5
Subwoofers: 2 JL Audio 12TW3-D4
Share this post
Link to post
Will vouch for the PG SX series. I've got one in my Corolla. A bit anemic on the sub channel for my liking but it's adequate to blend with the fronts nicely. (for reference it's a little longer than the 4 channel we used in by brother's F250 pictured). Nice efficient little amps, Zed designed, non regulated power supply but that's the tradeoff for small footprint and lower cost.
Share this post
Link to post
Thanks, Guys for the suggestions. I guess I'm going to change my strategy, and mount it under the passenger seat. The location behind the rear seats will be used for a single or dual sub box. Once I've decided on the amp, I'll be shopping the box and subs next.
Again thanks.
Share this post
Link to post
I’ve got a pair of stereo integrity bm mkiii subs I could sell you.
2004 Honda S2000
Pioneer DEH-80-PRS
Share this post
Link to post
Hell, the vast majority of 5 channel amps have fairly anemic subwoofer channels. But 400 watts at 2 ohms on the sx1200.5 is on par with most 5 channels. I have two of the pg ti21600.5 which has twice the power on the sub channel. Good little amps.
2004 Honda S2000
Pioneer DEH-80-PRS
Share this post
Link to post
I’m about to get a 5 channel that cuts my sub power down to 1/3rd. I think I’ll be ok.
JBL MS-8
Hertz HV165XL
Share this post
Link to post
I expect the real trick is choosing a sub that works well on 300W... I mean back in the old days 300W was a strong sub stage. I bet a JL W0 would probably outperform the sub I have on there now but I just sort of threw in a box I had with a sub I built quick with a used coil and some very cheap parts.
Share this post
Link to post
The Q will do fine. I’d doubt it’s seeing that much now.
JBL MS-8
Hertz HV165XL
Share this post
Link to post
You're not trying to get crazy either so as far as blending nice with your music I'm sure you'll be happy.
Share this post
Link to post
I just hope the one I want don’t sell out. It’s NOS and they never pop up. It was my dream amp 10 years ago.
JBL MS-8
Hertz HV165XL
Share this post
Link to post
Rockford Power 1000 25 to life?
Only really special limited edition multichannel I can think of hitting the scene since Memphis Belle.
Share this post
Link to post
Create a free account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's free & easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
