Opps measure twice
  • 4
ronin1717
tx
Ok so opps made a mistake...yaddi yaddi yaddi
Had my cuts made for an subs up port back areo port enclosure.
Opps right measurements wrong cuts or however you'd say it. My top/bottom cuts are my front / back of that makes any sense.
Any suggestions other than re-cut , since that's a known option.
Buy more wood and recut the top and bottom or cut the side panels shorter for less depth. Did you give the correct dimensions to whoever cut the wood? If so and if its a store then I would back there and make them give you the correct sizes.
[quote name='Boomin_tahoe']Tightbond
Only logical fix would be recut those pieces again. Don't want any gaps of any size.[/QUOTE]
Quote Originally Posted by Boomin_tahoe View Post
It's "oops"
Opps! it is oops opps did it again lol
Anywho... Thanks @THATpurpleKUSH I just did re cuts
Yep you're right re cuts done
Thanks for the titebond recommendation.
that's what I had planned just checking other options
[quote name='ronin1717']Opps! it is oops opps did it again lol
Anywho... Thanks @THATpurpleKUSH I just did re cuts[/QUOTE]
YW, just beware that your net volume is now smaller which will shift the port tune slightly higher. I use Titebond to glue the panels together then I use DAP Alex Plus Fast Dry to seal the inner seams. That way I know the seams have no leaks.
It all worked out , they laughed at my mistake so I got enough extra board to re-cut the 2 short pieces...all original dimensions now.
Thanks
Ok so opps made a mistake...yaddi yaddi yaddiHad my cuts made for an subs up port back areo port enclosure.
You can make the box slightly smaller..it shouldn’t make much difference
Time alignment is used to delay every speaker closer than the furthest to have the sound hit the listeners ears at exactly the right time. If this...
440
ronin1717
ronin1717
tx
Louisiana_CRX
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
