Jump to content
Sign in to follow this
ronin1717
Opps measure twice
Recommended Posts
Ok so opps made a mistake...yaddi yaddi yaddi
Had my cuts made for an subs up port back areo port enclosure.
Opps right measurements wrong cuts or however you'd say it. My top/bottom cuts are my front / back of that makes any sense.
Any suggestions other than re-cut , since that's a known option.
Share this post
Link to post
Share on other sites
Buy more wood and recut the top and bottom or cut the side panels shorter for less depth. Did you give the correct dimensions to whoever cut the wood? If so and if its a store then I would back there and make them give you the correct sizes.
Share this post
Link to post
Tightbond
Only logical fix would be recut those pieces again. Don't want any gaps of any size.
Share this post
Link to post
[quote name='Boomin_tahoe']Tightbond
Only logical fix would be recut those pieces again. Don't want any gaps of any size.[/QUOTE]
Quote Originally Posted by Boomin_tahoe View Post
It's "oops"
Opps! it is oops opps did it again lol
Anywho... Thanks @THATpurpleKUSH I just did re cuts
Yep you're right re cuts done
Thanks for the titebond recommendation.
that's what I had planned just checking other options
Share this post
Link to post
[quote name='ronin1717']Opps! it is oops opps did it again lol
Anywho... Thanks @THATpurpleKUSH I just did re cuts[/QUOTE]
YW, just beware that your net volume is now smaller which will shift the port tune slightly higher. I use Titebond to glue the panels together then I use DAP Alex Plus Fast Dry to seal the inner seams. That way I know the seams have no leaks.
Share this post
Link to post
It all worked out , they laughed at my mistake so I got enough extra board to re-cut the 2 short pieces...all original dimensions now.
Thanks
Share this post
Link to post
You can make the box slightly smaller..it shouldn’t make much difference
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    No registered users viewing this page.
