Top five amplifier companies?
asking for the top five is going to make your budget seem massive hence why i asked your budget
mmats is probably what id get if i had an unlimited budget
Budget= $350 max for the amp
350 max for the amp will require you to get a 200 dollar 2ndary battery and 50 dollars for a big 3 upgrade kit which total to 600 dollars total. There's no avoiding electrical upgrades when you have a sub like an FI Q. If your car has a sh*tty stock alt then you are looking at a 400-800 dollar alternator upgrade as well on top of that 600.
Sorry guys
I honestly have no idea what good amps are now days
There's a handful of brands who still do R&D and there may be a couple that actually build their amps in the first world.
So you're probably not looking for the top brand at this price point if you're trying to buy new. IMO a 1200-1500W amp should hang off of factory electrical well enough so I wouldn't think you'll need to get too crazy with auxiliary batteries or high output alternators. There's going to be a dozen "brands" that are basically the same Korean class D boards in different heat sinks. Any of them should serve you well enough. More importantly be sure you get a proper box built for that Q if you want good results here.
You only need one thread to figure this amp selection out.
It would be easy to just grab a 2k amp but it takes power to make power.
Is this a new Q or older one
Is it upgraded
The correct box built for it
What's the deal with mmats? I know two things: 1) Expensive. 2) Claims to make amps in their own shop in Florida.
CAF, Williston Audio Labs(Old School Car Audio) and Jonathan Patrick's Brand X videos when I'm trying to wire an alt into a newer vehicle I...
16
Welcome Fran. Just connect them. 20 watts RMS will play fine with 100 watts RMS speakers. You will hear the limits of the radio so just use it...
The CT's are nice, That Sundown is a a frik'n beast!
497
521
jeeper2269
jeeper2269
Somewhere, OR
BOOMINGRANDPA
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
