On/off switch for rearview camera
  • 2
the best advice I can gicve is to run it through a relay where either source would close the coil to energize the cam. since it would be using 2 seperate 12v sources 1) the rear tail light, 2) the switch you control. the other thing I can think of is 3 way switching as in a house where you can turn on and off from 2 or more locations.
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
733
Thank you all for all the replies, I intend to reply to each and every one individually as I test things out. Here's the latest development that...
13
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
944
GreenSmoke
GreenSmoke
Dallas, Texas
tommydh
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
