Static Hiss // Ground Loop Isolator Help
gdotcastro
Installed my first car audio system last month and extremely happy with the results.
Sounds great, get's the job done, and it was within my budget.
I started tuning my amps and getting the best sound possible out of my system, but noticed I have a faint hiss // static noise in the background.
4-Channel amp gain is turned all the way DOWN to prevent the hiss from being louder...Higher the gain, louder the hiss becomes.
When I connect my phone and pause the music, I can hear the hiss. If i'm listening to music, I don't hear it at all. It's still there but you can't really hear it over vocals.
I've done a bit of research and found the PAC-SNI-1 Ground Loop Isolator and hoping it helps eliminate this static noise but I have no clue how to install the thing!
I have a 2016 Jeep Wrangler with a stock 430N HU that uses a PAC AOEM-CHR3 adapter which connects to my mono amp + 4-chan amp. For installation, I tried connecting the PAC GLI directly to the amp, but I still got static noise. There are also 2 brown wires on the PAC GLI which are the ground wires, not sure where to ground these...Do I run them directly to my amp's ground or splice into an area behind my HU?
Thanks!
Learn about grounding first, Google it, and isolate the issue, when I started I tried those things and they didn't do st*t, my amps and hu sharing the same ground fixed everything for me.
Try and use the factory ground wire in the harness instead of chassis ground to see if it makes a difference
859
I was listening to music one day and after pausing it on my phone (i was using Bluetooth) there was a very present static, It has been working...
Sounds like HU, but I'd try hooking up the speakers to a different source as a troubleshooting step. The professional installer who charged for...
gdotcastro
gdotcastro
Portland, OR
Chris McNeeley
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
