HU Crossover or Amp Crossover??
bbrodin
Just purchased a Sony HU that allows me to set crossover points. Does it affect the sound or make a difference if the xover is set with the amp or the HU. I would prefer to set it on the HU as I can pick the precise Hz, rather than guessing on an analog knob. I assume that I would just need to turn all xovers on the amp to their base numbers and let the HU do the work. Does it make a difference? Thoughts?
If you use both crossovers you would change your slope and you my have under over lap frequency gaps ..it’s best to use the decks crossover and set your amp flat and bypass ..
Only has a 50-250hz knob. Its a 1 channel amp a RF 501bd
If the amp lp is undefeatable id just use the amps LPF like I said using multiple crossovers deck processor amp ..ect increases your crossover slope and will have weird effects on the sound ..your deck should have a setting for through but still maintain the sub level for adjusting bass level ..I’ve done a lot of research on this area when I was competing ..because a lot of the bigger amps had undefeatable crossovers as well ..I’ve gained over a decibel in competition by just using the amps crossover and bypassing the decks internals ..
Can overlap and gap be used in same context 😂😂😂
Ok so it's best to use deck. Great thanks answers my question.
...even on a holiday.
Not this one ☝😂😂😂
If the amp lp is undefeatable id just use the amps LPF like I said using multiple crossovers deck processor amp ..ect increases your crossover slope and will have weird effects on the sound ..your deck should have a setting for through but still maintain the sub level for adjusting bass level ..I’ve done a lot of research on this area when I was competing ..because a lot of the bigger amps had undefeatable crossovers as well ..I’ve gained over a decibel in competition by just using the amps crossover and bypassing the decks internalsintern
Incressing slope does not always equal bad effects
Ok so it's best to use amp. Or not! Lol
I like to use both. Is there not an application for this? Why choose between hu with limited frequencies cross or amp with limited slopes ect. Using both will give steeper slopes and more frequencies to choose from. sometimes this is encouraged/sought after. No? Thanks
Not this one ☝😂😂😂
necro commenting again, YAY!!!
There's definitely quite a few that can give a better answer, but IMO, it's (1) 8" sub. It's supposed to be quicky and jabby, not a power...
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
145
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
883
bbrodin
bbrodin
Roanoke, VA
Talontsi90
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
