Single 12 or 2 10s
I agree with audiobahn. I've heard nothing but great things about the xfl's, especially for the price. I had a DC lvl 4 and liked it but didn't love it. I'd get the xfl's and spend the savings on other upgrades.
Everything I’ve seen and read seems like the xfls need more air space than I have to sound good. The dc xl 10s only call for 1 cuft per sub ported so I have room to oversize it a bit to hit the lows.
You have 3 to 3.5 cubes to work with? Is that before sub and port displacement?
I currently have 4 sundown x8s in a ported box I have 2 of the 8s inverted in order to get my 3cuft. Box is almost 4 prior to port and sub displacement.
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
326
585
gmc123
gmc123
Fla
kr15
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
