4-5k Watt Mono Amp
I have this
Sent from my SamsungLife using Tapatalk
We had a local competitor completely drop Soundigital and switched over to Taramp's Bass line.
These are his words as we do not follow people so no idea what he was doing score-wise and all of his troubles he had with SD-
When we first gave him the bass 12k(he had an SD12kevo), he said- ****.. this bass12k weighs a LOT more than that sd12k i had.
He said the 12k couldnt handle slow roll burps of up to 15s show after show without popping fets. He had it repaired at least twice from what i gathered and tired of the company giving excuses as to them not wanting to cover it anymore.
He said the amp got too hot because SD isn't using proper heatsink. It's extremely thin and not dissipating heat for such use.
I've never handled the new ones so i can't comment at all on that but the bass line is stout.
It's pretty apparent that the Taramp's has twice as many onboard connections than the SD amp has which implies the major differences of their intended use..
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
Falco78
Falco78
Winchester, VA
MrFoca
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
