Starting my build 2015 Ford Fusion
Polar
First off, the car
So far I have acquired a Crunch GP3000d pro amp to power up a single HDC312
a Xenon PG X200.4 amp to power a set of image dynamics 6.5 components
Sub should be here next week. Im going to take my time, deaden the hell out of everything and do this clean. Hoping to sound good when Im done. I welcome any criticism as Im no pro here.
hey i never even took that cover off since i bought that ground pounder brand new
update your signature with the Korean Sisters
Crunch GP3000.D Pro
Pheonix Gold X200.4
SoundQubed HDC312
I had those same exact battery terminals and the POS side broke. They were very cheap...I think like 15 bucks for the pair or close to it. So beware/just a heads up...
Ive got a new (3) spot for zero gauge, I still have to do the power wire to the alt for the big 3, which is a pain in the *** to get at my alternator on my car. I have to take the front end off next week to adjust the coil overs so Ill do that then.
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
ok so i realized the one u gave in the example did the same video stuff so i see the one mentions 13 band equalizer but the other has "higher"...
17
16
651
849
Polar
Polar
WPB, Florida
350zspl
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
