Memphis PRX1500.1 and PPI Phantom P600.2
Beerdrnkr
San Diego
Memphis PRX1500.1 sub amp
PPI Phantom P600.2
Memphis amp is physically about 6-7/10.
PPI amp is in very good overall condition.
Memphis PRX1500.1:
mono subwoofer amplifier
600 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
1,500 watts RMS x 1 at 1 ohm
variable low-pass filter (50-180 Hz, 12 dB/octave)
variable bass boost (0-12 dB at 45 Hz)
variable subsonic filter (20-50 Hz, 12 dB/octave)
Other Features:
preamp inputs and outputs
speaker-level inputs
wired remote level control included
removable magnetic "M" badge conceals top-mounted controls
LED accent lighting
fuse rating: 150A x 1
4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
frequency response: 20-180 Hz
dimensions: 15-3/8"W x 2-1/16"H x 7-3/8"D
PPI Phantom P600.2
RMS Power Rating (14.4V): 4 ohms: 190 watts x 2 chan./2 ohms: 300 watts x 2 chan./Bridged, 4 ohms: 600 watts x 1 chan.
RMS Power Rating (12V): 4 ohms: 100 watts x 2 chan./2 ohms: 200 watts x 2 chan./Bridged, 4 ohms: 400 watts x 1 chan.
MOSFET power supply
LED power (green) and protect (red) indicators
Heavy duty aluminum alloy heat sink for extreme heat dissipation
Memphis $300 obo shipped
PPI $80 shipped.
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
805
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
856
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
4K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
Beerdrnkr
Beerdrnkr
San Diego
Boominburban
    Apr 24, 2024
Deepak Walia
    Apr 23, 2024
