In home setup
  • 2
Jackfitz5
Hi, I am wanting to test some stuff before I install/sell and I would like to do so in the house. I understand that hooking up a car battery charger isn't the best idea because a charging battery will emit hydrogen gas. However, due to the fact that I'm not trying to consistently run a system for long periods of time (maybe one song at a time), can I charge a car battery outside and then bring it in... Then proceed to run the system off of a car battery? Is this safe? Are there better ways to do this without absolutely breaking the bank? I've heard of Xbox and pc power supplies but it doesn't seem they're strong enough and I don't want to spend too much time if I'm only testing inside. Please let me know. Thank you.
dont use lead acid. Use agm sealed batteries for at home test benches. You can use pc power supplies for weak amps but anything over 500 watts, you wont get anywhere close to what the amp can actually do.
  • Locked
Hello all, I am new to this forum but have had no luck on ebay/gumtree/fbmarketplace regarding trying to shift my aftermarket car audio setup. My...
Here is the plan. My car is on a bit of an incline, the nose is sitting about half a foot higher than the rear. The little bit of windshield...
434
I was browsing parts express. It seemed like around $180 for a 300 watt plate amp. The dimensions are not identical, new amps seem larger by a few...
935
I haven't had a proper home theater or home audio system in quite a few years but here's what I remember. I like both systems to perform the same...
14
Hey guys didn't realize this thread got revived. Decided to bite the bullet and buy a used Yamaha receiver. 6 channels 100 wats per channel with...
13
Jackfitz5
Jackfitz5
Buffalo, NY
Jeffdachef
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
