FS Crunch GP3000D
350zspl
WPB Florida
GP3000D Ground Pounder Crunch
Clean & Pristine Condition
Functions Perfect
Rated
750 x 1 @ 4
1500 x 1 @ 2
3000 x 1 @ 1
$325 Shipped & Pay Palled Lower 48
Copied from the net
Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts
That's a lot of coin for a Crunch/Maxxsonics amp.........
Its worth every penny, its one of those diamond in the rough amps that you find in a giant crunched up pyle of sh*t. These amps made serious power korean built, if you didnt check the "made in korea" sticker. Basically a korean 3k
I swapped out the GP 3000 to down size to a SCV2000 Sundown.
Output seems like 1/2 as much, on my ear dyno , LOL .
350zspl
350zspl
WPB Florida
350zspl
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
