Plans on new sub & amp combo, need advice
Hi guys. Let's jump straight into it, I currently have a kicker c10 and c12 in sealed boxes, powered by a 900 watt pioneer amp. I'm looking to upgrade to something with more bass. I need some advice on some good sub and amp combos are. I do want either a vented or bandpass box. I would also like 2 12 inch subs. Maybe 15s I'm not sure I don't have a large budget either so nothing to expensive.
I kinda have an idea of what subs to get but it's a toss up. I'm thinking about getting.
2 Jl audio w3v3 12", Rms-500, peak-1000, 2 ohm
2 Kicker Comp vx 12", Rms-750, peak-1500, 2ohm dvc
2 Kicker solo Baric 15", Rms 1,000, peak-2,000, dual 4ohm
2 Rockford Fosgate punch 12", Rms-600, peak-1,200, dual 4ohm
2 orion xtr pro 12", 1,250 Rms, 2,500 nominal, 5,000 max
Do you know how much space you have to work with? With that budget you could def get a custom box an some good budget quality subs.
It's in the back of a 1996 ford ranger extended cab. I'm not sure on the exact space I have to work with
Sent from my SM-G930V using Tapatalk
Here's a picture minus minus the cup holders
Well if your wanting something with quality I’d go with something like this-
Pair of these or 15s https://m.ebay.com/itm/SUNDOWN-AUDIO-E-12-V-3-D4-12-500W-RMS-DUAL-4-OHM-CAR-SUBWOOFER-BASS-SPEAKER-NEW/131743665493?epid=1894698002&hash=item1eac88cd55:g:eMIAAOSwv9hW2iTQ
This amp * NEW * CAB-1600.1 Amplifier - Car Audio Bargain
Can you build a box or would you need someone to do it for you? If you could build it your self you possibly could have some $$$ left over to put else like wiring etc.
what model# is that amp? Im assuming that's peak power 900? Peak power is pretty much irrelevant just worry about rms. Sounds like you'll probably need a mono amp use the 2 channel for mids n highs. Just trying to figure out your current set up. Not a good idea to use different size subs too.
I'll have to look at those. Id need someone to make the box for me.
The amp model is gm-a5602. And I said this earlier I'm a bit of a noob. My head unit is a power acoustik pdn-621hb
Are you in any groups on Facebook? You could start by asking there to find someone local maybe in your area or surrounding areas preferably someone who could design the box as well.
I can go as big as i want really,. But my max area i want to dedicate to it is, 36w x 15t x 15d. Single 12 dvc 4ohm wired to 2ohm with 800watts...
First and foremost is that the sub must be designed to work in a small enclosure. If not designed for it, you may end up with less bass than the...
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
480
Haywardr23
Castle Dale, utah
shredder2
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
