Which amp poll.
Most efficent amp at .5 nominal
  • Total voters
    17
Amp models would help also lol. I love sundown if you can afford (the sae line isn't that expensive but the other line is). Orion xtr amps are cheap and put out real good numbers though.
I think Vital power and b2 use same / similar guts on comparable amps. Sundown scv-7500d can be had for around $2000.
VP 700.1 can be had around $1100, and probably the b2 also I am assuming. Orion HCCA8000.1D can be had for just shy of $1100.
It comes down to what you want. You have a budget or can you get a good deal on 1 out of the bunch?
I think Vital power and b2 use same / similar guts on comparable amps. Sundown scv-7500d can be had for around $2000.VP 700.1 can be had around $1100, and probably the b2 also I am assuming. Orion HCCA8000.1D can be had for just shy of $1100.
The money doesn't matter really. I just want the most efficent amp.
8k plus models
Orion hcca 8000.1d or 110001d
Vital power is supported to be I guess 7kw but it does more.
The b2 M1U
SUNDOWN 7500
I might end up doing 18v so I'm not sure. Only one that is 18v stable is the VP
The HU us likley 12-15 x 4 at best so yes, using an amp will be hugely beneficial, night and day. The HU us not going to drive a sub to any...
71
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
235
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
251
11
252
Papermaker85
Banned
Papermaker85
New orleans LA
Papermaker85
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
