2 amps getting power + remote, not turning on.
docstrange82
I can't for the life of me figure this one out.
The power and grounds are both good according to my DMM.
The remote wire is getting power (0.1-0.2v)
The remote wire is hooked to the blue and white wire.
I've tried 2 amps, 2 fuses, and 2 capacitors.
DEX-6900BT Pioneer radio
Hifonics ZRX3216.1D Zeus and also tried Skar Audio RP-2000.1D (thought the amp was bad).
All the other speakers and such work, so totally at a loss.
I can't for the life of me figure this one out. The power and grounds are both good according to my DMM.
whats the problem ?amp not turning on
so lights don't come on amp?, if they do come on u did hook up rcas right? if not did u connect remote wire to switch power? u can stick wire under a switched fuse in fuse box..
remote wire should be getting 12 volts not .1 or .2 volts
I am not privy to the color coding for your hu... is the blue/white wire for a remote turn on wire or possibly a power antenna turn on lead?.. I'm reaching here but have seen something similar once... maybe the hu is bad?.. otherwise try jumping power from the power terminal to the remote... if that works then you'll need to find another switched source... but ^^^^ is correct... you should get 12v on the remote wire... not less than a volt
im pretty sure most power antenna leads are also 12v but is only active when the tuner is enabled on some head units. it sounds more like a pinched or shorted wire
im pretty sure most power antenna leads are also 12v and can be used as a remote wire as well it sounds more like a pinched or shorted wire
They are 12v... but some only go active when the tuner is in use... no kiddding... lol... it got me once
Just throwing out ideas
Exactly what I was thinking about the antenna wire. The remote wire is switched on by the h/u so it sounds like the remote wire isn't getting power, so make sure you have the right wire from the h/u. I've seen solid blue and blue/white interchanged for the remote lead.
yeah i did remember that i just havent used a tuner in about 15 years lol just to use the auto preset option then never to be heard from again.
It'll still be active with the preset... but be off when using the aux, cd, bt.... etc possibly... just jump from the power terminal to the remote for a fast diagnosis... if the amp turns on it's the source thats not supplying 12v... and then you can go from there... good luck
I would ditch the capacitors....once the electrical is beefed up, won't need them. How old is the HU? You may have to go into settings menu and disable the internal amp. Thus will run the power to amps only, and not from the HU.
When you do find a new Ground spot look for something existing that is tapped. If nothing like that is available make sure you cleanthe area to...
13
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
279
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
839
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
docstrange82
docstrange82
chicago
Boomin_tahoe
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
