Pure Audio 10" *Pa4x*
  • 3
:typing:Recently purchased some PURE AUDIO 10" subwoofers,i believe the guy called them Pa4x subs. I noticed (trying to find specs/info on them there is nothing anywhere) so I just recently cut the cut out diameter out of cardboard. its right on the edge of the basket #perfectfit . The outer diameter is 11" (the ring where you would put the screws) and the cut out diameter is 9 1/4" (you can, I do , cut it to 9 1/4 + a blade 1/16th) to make sure its not too tight. so ill do my best to keep the info coming try to help all those who buy PURE AUDIO.
Losing a lot of cone area. Might make up for it with power. Keep us informed, build pics, etc....
4
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
230
@Dappster360
@Dappster360
Baton Rouge,La
MrFoca
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
