Spadepro22
If my box is being tuned to 32hz, how do I adjust the subsonic and low pass on the amp?
60hz on the hu under the Subwoofer setting? I have a pioneer and it has a million settings I don't understand lol. What would the difference between 60hz and 80hz? I need help with the understanding of the HU and amp.You would set ssf at 25hz.
Personally, I set my ssf about 4-ish hz below my box tune. Especially if you have headroom with your amp, you could start bottoming out that coil real quick.
Your LPF is your preference. I have mine at 60hz on my HU and it's closely matched on my amp.
Some people will set it higher, more around the 80hz range.
i'd recommend googling every setting your pioneer has and learning about hz and frequencies outright. It'll be a 2 hour lecture to teach you all these questions you ask lol.60hz on the hu under the Subwoofer setting? I have a pioneer and it has a million settings I don't understand lol. What would the difference between 60hz and 80hz? I need help with the understanding of the HU and amp.
Set this on the amp correct?You could just set lpf for 80 and ssf for 25-30Those are fairly common settings
You can always change them
yeah but if u have lp xover on hu u can use that just because it's easier to change and u have more exact # u can see being digital... at amp turn it to off/pass though or just all the way up like 200 or whatever it goes to, once u have it set to 80-100hz on hu...Set this on the amp correct?
Yes I have the lpf on the amp and hu..... Sorry to be so repetitive....just tryin to get it right. So on the lp on the amp turn it all the way up and adjust it from the hu? The pic in the original post is my actual amp. On amp lp goes to 250hz and sub sonic goes to 35hz. Let me add that it has lp setting under Subwoofer central and in regular settings.yeah but if u have lp xover on hu u can use that just because it's easier to change and u have more exact # u can see being digital... at amp turn it to off/pass though or just all the way up like 200 or whatever it goes to, once u have it set to 80-100hz on hu...
yep thats how mine is 120hz on hu and 200 on amp.. just do it turn it up 1/2 way and go listen to sub if no words are coming out of sub it's good, u can't hurt anything..Yes I have the lpf on the amp and hu..... Sorry to be so repetitive....just tryin to get it right. So on the lp on the amp turn it all the way up and adjust it from the hu? The pic in the original post is my actual amp. On amp lp goes to 250hz and sub sonic goes to 35hz. Let me add that it has lp setting under Subwoofer central and in regular settings.
Depends on what freq you're changing.Ok cool. My box should be done next week and I'll give it a go. Another question is will changing the eq settings change the way the sub sounds or does the eq only adjust highs and mids?
