2011 Challenger Build
  • 6
moparnut
After not working with car audio for almost 20 years it was time. I am doing a modest budget build in my Challenger. The box is a transmission line (my first time building one of them) with a port length of almost 8 ft. I already know the port is a little short, however it is tuned around 36Hz and is hitting 126. For a single sub on less than 300 I'll take it. There is still some work and I will update this thread as progress happens. I am open to suggestions that any may have.
https://imgur.com/mSHBskk
https://imgur.com/6gyVJqP
https://imgur.com/t7RQ5Jw
https://imgur.com/6sF143m
https://imgur.com/FvVq9Ee
Adding the last 45's
https://imgur.com/IHtCkOa
https://imgur.com/7RcYpYX
https://imgur.com/JKjATeL
https://imgur.com/bJGFIhQ
I can't get the pics to load
yeah just get a nicer d4 sub u be fine.. just since u tuned like me that amp don't have a ss filter..
Getting ready to order a PPI d2 sub (either phantom or power series, I haven't decided). I can then run the amp at 1 ohm.
I should be starting on the amp racks soon.
Here are the build pics now that I know how. Grey window trim is magnetically fastened. The box now has has been turned around and the sub facing the rear of the car. I'm doing invisible mounts floating mounts for the amps. Amp rack pics coming soon.
I did. The line is roughly 7 1/2 feet, which comes up a little short. I am going to extend it about 18 more inches. There is only the one opening in the top visible in the first pic. The two in the back are acrylic windows and are sealed.
I got the amp mounted in the trunk over the weekend. I went with a hidden mount and I am very happy with the way it turned out. The LED's aren't quite so bright in person. Let me know what you all think. Either the port lengthening and trim panels around the box or the highs and mids are next. I haven't decided. I still have to get the Pioneer 8604 for the rest of the speakers.
The port is too long and isn't tuned to fs.
It should be more like 6-6.25 ft for fs of 30.5hz.
Also the qts and qms are higher than the ideal numbers for a t line. I wouldn't have put that sub in a t line personally but if you're happy then fuck it.
Which sub are you referring to? If you are referring to the Fosgate, then yes I agree. It went in there as a placeholder and had been replaced recently with a JL Audio 12W0 that I picked up for $40, which sounds pretty good. The PPI by my calculations should work great. The QTS should be something .40 and lower, which the PPI is .4 and the QMS should be lower than 7, which the PPI is 5.46.
As for the port length, the Fs of the PPI is 29, which according to my math (1130/29 = 38.96 Ft long port for full sound wave, 38.96/4 = 9.74 ft long port for 1/4 wave Tline)
The current port length of 7.5 ft tunes out to roughly 37-38 Hz. The box really does come alive at that freq, but I want more lower end out of it.
I ordered the PPI P.12D2 and it should be here Monday, so I'll find out soon enough.
The PPI showed up yesterday and the box was too shallow at the opening to mount it, so sometimes things have to get uglier before they get pretty. The white patch will get covered in gray vinyl when I recover the box. No biggie since I have to lengthen the port and recover the box anyhow. That'll tune the box to 30Hz when done. It is running at 1 ohm getting 800 from the amp. What a difference that 500 watts makes. Those who may wonder about this sub, I think it is a great contender for a budget build. I definitely only need the one.
Not much here other than crickets, but I'll add these anyhow. I didn't like the panel above and it had to go and I changed the port location. It is much cleaner now. I got the inside part of the trunk wall almost completed over the weekend. Just have to trim it out and put a floor piece in. The back side vanity panels will be the next major part and will be done from fiberglass so I don't have one large block in the trunk. I still am able to get the trunk floor in and out as well as access the spare tire. This car has a huge trunk. Here's the pics.
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
5K
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
moparnut
moparnut
Wagoner, OK
moparnut
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
