Enough venting?
  • 6
I have a box for 2 8s that measures 5 10/12ths of top mounting depth. I was looking at the soundqubed hds208s that require 5.5" of mounting depth. Is my box deep Enough? If not then I'm just going to go the sundown e8 route.
yeah it's nice to have an inch from back wall.. could u add 3/4 wood baffle on front of box?
Worst case you could chamfer the back wall on the inside about the diameter of the motor back that way you get a little more room to keep from starving the coil for air.
0.8333333333333333333333333333333333333333333333333 inches.
These weird numbers....I don't know where they're getting them but it makes it confusing. I see what you did there....just divide 10 into 12 and come up with what you replied.
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Like OP stated, there are radios with higher power output. Most radios have around 18 watts RMS per channel. They mostly claim 50w per channel but...
18
Chad21000
Chad21000
Savannah GA
Boomin_tahoe
vlusardi
    Apr 24, 2024
vlusardi
    Apr 24, 2024
