Putting together a garage system with 6x9s and a deck, need help.
ArmyNavyCopGuy
I wired an xbox 360 power supply to an old bluetooth Pioneer deck. Everything works
but my issue is that there is not much bass coming from the speakers. I understand that they
aren't amped but I still feel like they should be hitting a bit harder.
One thing I noticed, the cones dont move in the box, but out they move a lot. Do I need a different type of box?
A friend of mine, this was back in the late 70's, built a box and installed a pair of 6x9's, a head unit and a 12v to 120 power converter. He placed in on the fireplace mantle and it sounded quite good. The speakers had individual chambers so the bass was pretty good.
Gotta o/s 8" Cerwin Vega sub in my garage off my everlasting JVC home receiver I bought in my teen years that still works to this very day. Along with some older work Sony bookshelf speakers mounted high. Doesn't sound bad and can get a lil loud.
Get a hpf and a cheap 12” sub. Ive got a kicker 12” that i had sitting around powered by a xbox power supply and a dual hu out of a jeep we got and just off hu power it’s plenty of bass
Does my home office count as a garage system? Dual 150 amp 110v to 12v converters connected to a pioneer premier deck, A kicker 1200 amp connected to a fu audio 750 12 and a crown x1000 connected to a pair of triangle Celius towers.. my room gets loud when I'm not testing amps.
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
Yup I replaced door speakers and just replaced rear speakers yesterday. What it was I had to adjust the crossovers
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
ArmyNavyCopGuy
ArmyNavyCopGuy
long island ny
bigblank69
    Mar 28, 2024
    Mar 28, 2024
