Adding amp and speakers to stock HU.
v1ks_
15
EU
Hello there,
Another noob here, in need of help. I'm terribly, terribly sorry if I'm asking something that has been covered 101 time, but at the moment I'm just sick and tired of Google searches and trying to figure out what's right and what's a bag of bullcrap. The fact I'm new to this and don't know how half of the stuff is properly called, and the fact that English is not my native language, doesn't help either...
I'm looking to replace my factory speakers with aftermarket ones, feeding them off an amp, but retaining the stock head unit. The reason I sort of have to keep the stock head unit is because it's integrated with climate control. Here's the list I'm working with at the moment:
1) 2005 Honda Accord 2.0 (European version)
2) Pioneer D8604 amp (4x100W RMS@4Ohms)
3) Hertz DSK 165.3 comp speakers (80W RMS@4Ohms)
4) Gladen WK20 4awg amp wiring kit
5) Yatour BTA bluetooth and line-in adapter using stock HU's CD changer port
Now, since I mostly will be streaming Spotify from my phone and since I'm sort of stuck with the stock HU, I have no ambitions for a high-end, audiophile grade system. All I want is that it sounds -good-.
There are two pieces missing in my puzzle at the moment and those are:
1) How to wire stock head unit to the amp
2) Which of the following routes to go:
2.1) Comp up front + sub in the rear
2.2) Comp up front + coax 6x9 in rear deck
Today I visited a local store that specializes in aftermarket car audio to pick up the wire kit for the amp. While there I enquired what's the best route to take. They strongly advised not to use a LOC, or if I really want to take that route, to buy the most expensive one I can get, because it will degrade the signal quality. Instead, they suggested I splice the speaker/high level outputs from the factory HU and connect them directly to amp, as it does have a high level input option.
As for number 2, they suggest I get a pair of 100W RMS 6x9's instead of a sub, as those would still deliver somewhat decent bass and would offer an overall better listening experience, compared to a ~250W RMS sub (amp supposedly is good for up to 300W@4Ohm while bridged).
Another thing they suggested, is to get rid of the 80W RMS Hertz components and get something more powerful, as the amp is too powerful for them, even at 'normal' gain level. He said they normally wire these speakers to aftermarket head units, without using an amp and that's all they're good for.
Now, on one had I have no reason not to believe them, but the more I read, the less I understand.
Can anyone here shed some light, give their two cents, express their opinion on the matter and so forth?
I'll be very, very thankful!
P.S.
Apologies for grammar, writing in a foreign language here, heh.
P.P.S
Not from US of A, but I'm pretty sure the "random" question during registration requires an answer that is wrong...
@Jeffdachef another one lol
I'm wondering how a stock HU has the climate controls? Should be separate....unless it's within the same area. Can you post a pic of the stock HU?
Hello there,
P.S.
P.P.S
only thing that shop said right was not to use a line out convertor. Everything else is bad advice, those components can take an upwards of 125 watts if the power is clean.
Get a digital signal processor that can flatten the stock head unit's garbage EQ curve and get a clean flat signal along with being able to properly tune the setup like an audison bit 10 or bit one or a rockford dsr1 if that's cheaper. A sub is pretty necessary, 6x9 wont do anything good for the system nor produce anywhere close to the frequencies a sub can produce.
[quote name='Boomin_tahoe']@Jeffdachef another one lol
I'm wondering how a stock HU has the climate controls? Should be separate....unless it's within the same area. Can you post a pic of the stock HU?[/QUOTE]
Boy do I hope that "another one" is not a bad thing, heh...
Here's the stock head unit/radio:
Boy do I hope that "another one" is not a bad thing, heh...Here's the stock head unit/radio:
we get a lot of people with cheap and expensive line out convertors coming on here with problems or having poor sound/bass performance all the time and the root cause is the line out convertor with stock head unit combo.
Stock head units have a built in EQ curve and agressive high pass filter to protect the speakers from blowing along with trying to make them sound better with the built in EQ since the Stock speakers are crappy. With a line out convertor, you subject ALL your aftermarket equipment to that horrible factory tuning.
Thanks for the reply. DSP seems to me quite the overkill for this situation, but I understand what you're saying. Audison Bit 10 is 228 euros, or 270USD. I could, most likely, get a semi-decent aftermarket HU and an adapter for a 1DIN HU for half that price... Most of the time I see people doing this, with this specific car:
A single head unit would be optimal, You just said you wanted to retain the stock head unit so thats basically the best choice to retain the stock head unit. However if you can fit a single din head unit, definitely go to that option, its MUCH cheaper.
as for head units look for the ones that have these kinds of specs
24 bit dac, 13 band EQ, 3 pairs of 4 volt or higher preouts, time alignment. If it doesnt have these options, its either outdated or junk. Alpine brand of head unit is basically the same but with 9 band parametric EQ, They are good choices as well, just less EQ bands but still decent as long as it has time alignment, and high pre-out voltage.
on a side note. Wow the bit ten is cheaper for you guys then us, its 350 usd here.
Holyshit...how would one disassemble that? These newer vehicles, they're getting harder and harder to work on and sometimes even impossible to add aftermarket anything.
That bottom Pioneer HU looks idealish tho...it looks a little modified, a Metra kit or Scosche kit would be needed.
[quote name='Jeffdachef']A single head unit would be optimal, You just said you wanted to retain the stock head unit so thats basically the best choice to retain the stock head unit. However if you can fit a single din head unit, definitely go to that option, its MUCH cheaper.
on a side note. Wow the bit ten is cheaper for you guys then us, its 350 usd here.[/QUOTE]
Audison/Hertz afaik, are owned by the same people and both, again afaik, are EU based, which could be the reason why it's more expensive state-side. Shipping costs and taxes, most likely.
The reason I wanted to retain the stock HU is because it just looks better, imho, than two headunits. Also, I wouldn't have to live huge chunk of almost nonfunctional plastic and metal right in front of my eyes... :)
I also bought a bluetooth adapter with handsfree that plugs into stock HU CDC port and integrates steering wheel controls. Then again, I'm fairly sure I could re-sell it for ~50eur and put that money towards an aftermarket headunit.
@Boomin_tahoe
Can't really disassemble that. Well, technically you can, I mean, it's possible to take it apart, but I certainly wouldn't... :)
As far as the Pioneer pic, it is modified, yes. Those 'adapters' don't cost much. A quick google search netted this:
https://www.amazon.com/gp/offer-listing/B000KL113O/ref=dp_olp_0?ie=UTF8&condition=all
$25 is pretty reasonable, but I'd have to find one EU-side, otherwise I'd be paying a 'ton' to have it shipped (relative to the item price at least).
@Jeffdachef
Yeah, I've seen those too. There are also Chinese android headunits that actually fit in the place of stock headunit, with the dual zone climate control integrated in them, but the problem with those are the fact that they are Chinese android headunits that most likely doesn't sound much better than the stock.
As for 2DIN unit in the place of storage compartment, I don't really see the benefits of it. It's too low to be used for navigation comfortably, imho, and I won't be doing any web browsing or video playback in the car. Plus, it's actually nice to be able to at least store your wallet and/or phone within easy reach.
Might try and see if any car audio shops near you have an install kit. Rather than buying one online and paying outragous shipping..
[quote name='v1ks_']Audison/Hertz afaik, are owned by the same people and both, again afaik, are EU based, which could be the reason why it's more expensive state-side. Shipping costs and taxes, most likely.
@Boomin_tahoe
@Jeffdachef
As for 2DIN unit in the place of storage compartment, I don't really see the benefits of it. It's too low to be used for navigation comfortably, imho, and I won't be doing any web browsing or video playback in the car. Plus, it's actually nice to be able to at least store your wallet and/or phone within easy reach.[/QUOTE]
single din would be your best bet then. Just keep in mind the specs listed. If the head unit meets or exceeds those options then its a good head unit. Over in US, we have one that meets those requirements as cheap as 80 USD which includes a wiring harness and dash kit as well.
If you want the best single din under 1000 dollars, the pioneer 80 prs is better than anything on the market SQ wise. Otherwise its fine if you get any other kenwood, jvc, alpine, clarion or sony units that meet the specs listed.
CZ702 //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif (Had to rub it in)
Thanks. That makes sense. It sounds pretty good as is.
834
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
597
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
576
v1ks_
v1ks_
EU
Papermaker85
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
Latest topics
