trumpet 5,000+ posts
Barry Schanz
CDT Audio HD-6 Reference Mid-Woofers 6.7"
Look at this on eBay http://www.ebay.com/itm/332404434296
New, 1 taken out for photography
I believe the mids are critical to an awesome experience of blissfully enjoying your favorite song in the car.
When piecing together a car audio system to get it just right you need to be selective. Whether you're doing a 2-way or 3-way front stage these HD-6 mid-woofers are a solid foundation.
Message me to schedule your 1-on-1 consultation to map out your entire system.
Rubyservsales.com
See my other listings for a recommended companion product - F.A.S.T. Rings 6.5
HD-6
1 pr 6.7" mid-woofers*
Technical specs and contents:
Frequency response: 55Hz-6,000Hz
Power handling: 100WRMS (200 watts Pk) HPF 120Hz
Mounting depth: 2.75"
Cut out diameter: 5.87"
Cast frame: OD 6.75"
Cone: Reinforced mix fabric carbon compound
Magnet weight: 20 oz
Cone surround: Butyl rubber
Impedance: 4 ohms
Sensitivity: 93.1dB
Voice coil: 1.5” (30mm)
Fs: 78.5Hz
The Award winning HD-6 component driver*with “Contoured Dispersion” provides the ultimate solution to the sonically intense reverberant field car audio environment. The HD-6 Contoured Dispersion door mounted woofer produces a sonic image that virtually appears “right in front” of you. It offers maximum sound definition with a minimum of drivers. This means it’s also very easy to install. Simplicity at its best.
HD-6 is audiophile competition quality and literally shapes the sound so it appears where it’s supposed to be. Up front and on the Beat. Critical ears have turned to the HD-6 award winning woofer and you’ll be a believer too.
1 Year Limited Warranty
Free ground shipping
Rubyservsales.com
HD-6
Impedance: 4 ohms
Sensitivity: 93.1dB
Fs: 78.5Hz
