Sub or Amp Problem?
  • 4
johndavis46
Hey everyone. I have a new problem with my system. I changed amps 5 weeks ago, and it has been sounding really good since. Then all of the sudden, the speakers on my left side went out (not too worried about that, because it has happened before) but my subs started acting funny. The subs will be normal for 10-15 seconds, then they beat super fast like a machine gun, then go back to normal, and then repeat. Any ideas what is causing them to do this? I know basic electrical skills, but get confused on the amps, ohms, etc.
I have 2 Kicker 10" Comp Subs that are wired to a 600W Kenwood kac-729s amp. I'm pretty sure the subs are 4Ohm.
check all wires even ground (no paint under it) pull subs check them but 1st if u have box with 2 terminals unhook 1 sub see if it still does it, then try other sub etc.. really dumb Q but amp is wired to battery not straight to alt right?
Okay, I thought everything was good and tight, but I will double check. I had a loose ground a few weeks ago and it made a slower heartbeat thumping, and this time it is faster.. but I will check again.
And yes it is connected to my battery. Not alternator
Now the amp isn't working.. I have power between my ground and power cable, so those cables are good. I don't have a multimeter right now, so I'm not sure how much power is getting there, maybe not enough..? But there is no power in my wires that run to the subs. I don't know much about amps so I have no idea what is going on..
The light on the amp won't even illuminate now.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
481
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
636
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
483
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
johndavis46
johndavis46
Ogden, UT
johndavis46
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
