Subwoofer smoking...!?
Rocketsubs
i recently wired a 12" Rockford fosgate sub in my car. Amplifier, box, and speaker are all to specks and the right fit for each other. I started playing music and it sounded very soft. Almost inaudible and extremely hot to the touch. I turned it off immediately, turned the gain off and tried it again. After about 3-4 minutes I saw smoke again. And I turned it off immediately. I turned everything as low as I could get it and checked all my connections. Everything was good so I turned it back on and listened to it very low to see if I could hear anything wrong. Sub did not heat up again but still didn't sound right. I took the sub out of the box and smoke poured out... apparently I wired my dual voice coil wrong so they were fighting against each other. I fixed it and checked for any obvious sign of damage. Everything looked good and the speaker does not scratch when depressed by hand and does no longer get hot or sound soft. It sounds absolutely amazing!! I'm just worried that I may have damaged it in the begininning running it on very low volume and turned all the way down for about 10 minutes. Any insight to its condition!?
Some damage was probably done since smoke was pouring out of the box. May not be immediate, but smoke doesn't come out of nowhere. Something got burnt
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
It’s cool I know what you mean work is kicking my butt. Yea I was gonna get the XFL 10 and run it of the CT-1000.1D monoblock amp I have already...
17
326
Open screw holes sound like a little muffler, loose box panels sound like a massager on a wooden table.
20
440
You can add a passive x-over between the HK harness and Logic sub. Just know that an inline passive will also affect the HK sub's frequency curve...
515
Rocketsubs
Rocketsubs
Huntsville, AL
Haunz
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
