Ridgeline14
I have a pair of SA-8V3vs powered by a Precision Power p1000.1. I need something with a lil more power around 1500w. What amp would you guys recommend? Trying not to spend more than $350.
ppi 1k (i have 1) tested at 1162 rms @1 ohm so few hundred more watts may not be as noticeable as u think but maybe just not worth the $., u can get 2 cabs $400 for both if subs are wired at 2 ohm each sub would get 1200rms.. if u want 1500 at thats it get us acoustics mike it's on this website u can find it and look at this 2k amp Synergy Audio WFO 15.1D 2,000w RMS Mono Block - SSA STOREWhy do you say that; and what would you recommend?
It's always underpowered. Everything is. We don't use gear the same way it's used to get ratings.I already upgraded the box and it sounds a lot cleaner. I just new they were under powered because the PP 1000 was originally for the SD2's I originally had in there.
What vehicle is this installed in? Year/Make/Model pleaseI have a pair of SA-8V3vs powered by a Precision Power p1000.1. I need something with a lil more power around 1500w. What amp would you guys recommend? Trying not to spend more than $350.
