Arizona heat
Is the Arizona heat overheating your guys amps too? or does my amp just ****? I have a belva 5500d.
do u have a good ground is it tight?, no paint under it.. sometime either bad ground or thin wire can make amps over heat too..
lol...changing amps isn't gonna help your situation man. Where's the amp's current location? If it's in the trunk, well....
So...lemme get this straight: the amp goes into protect when you get into the car? But it does not go into protect when the ac is running.
It is hot out... I'm in East Chandler and the temp is 115 right now... but an amplifier should work irregardless... are you trying to run a low impedance?.. that can and will create thermal problems even failure!.. as someone stated Belva is not well regarded.
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
Are there any label making machines available that allow you to print directly on your currently owned heat shrink and not from a manufacturer...
Any air movement is helpful in keeping any amplifier running cooler as long as there is a way to release the heat build up. I install all my amps...
Upside down should be fine. Airflow is all that matters. My buddy did this install. I think 14 amps. Look at that sloppy wiring. 😂 Vegas don't play.
SuperScion9000
San tan valley, AZ
JerryEllis
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
