Pro Quality Mic and USB Pre Amp Kit
  • 1
trumpet
Barry Schanz
You need a professional quality microphone, and I have a kit you won't find anywhere else in one neat package. In the car audio realm the hot ticket for tuning is accurate acoustic measurements. This kit gives you a major leg up in hardware that also serves multiple purposes beyond RTA measurements.
Add a laptop or large tablet plus FREE Room EQ Wizard software.
Dayton EMM-6 XLR calibrated microphone
Calibration file is available from Dayton or I will send it to you.
Dayton Audio EMM-6 Electret Measurement Microphone
Art USB Dual Pre portable preamplifier and computer interface
ART Pro Audio
Fresh 9v battery included
14 ft professional quality XLR cable
Loopback cable to test soundcard latency
Leather carrying case
The USB Dual Pre is a full-featured high quality dual portable preamplifier and computer interface packed into a compact rugged case.
It is designed to work over a wide variety of applications from remote field recording to desktop/studio tracking. Each of the two low noise input channels has up to 48 dB of clean gain with signal present and clip LED indicators. Inputs can be either XLR balanced or 1/4-inch TRS. Each of the 1/4-inch TRS outputs is buffered low impedance balanced.
The USB Dual Pre is powered via the USB bus. An internal 9 Volt battery, or optional external 12V power supply (or any combination of USB, battery & power supply) can be used depending on application. When running powered by battery alone, you should expect in excess of 50 hours of operation with phantom power off. Battery life will drop to approximately 20 hours (depending on microphone) when phantom powering is engaged (still enough time to get through an average session).
The built-in low noise +48 Volt phantom power supply allows you to power up to 2 microphones as well as the preamplifier when running from any power sources including the USB bus.
For monitoring, an 1/8-inch TRS mini headphone jack with level and monitor mix controls on the rear allow for latency free local monitoring of the inputs while recording as well as playback monitoring of the USB bus. The monitor mix is also routed to the 1/4-inch TRS balanced outputs. This lets you use the 1/4-inch outputs as either preamplifier outputs or as the monitor feed to your powered monitors.
Price
$200
USPS Priority Mail shipping
$2500usd for all three Shipping and PayPal fees extra I have a few BNIB pro series in stock I'm moving. These 3 listed is a full 3way system...
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that...
That is strange there. Thats what Ive encountered with low voltage before . That Kenwood needed a Firmware update and that fixed that one when it...
17
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
Bobbytwonames
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
