I have a constant buzz/white noise when the car is off/on. Its not alternator whine, its a constant steady tone. Unplugging rcas from amp ends the static. When playing ito amp from phone the static is gone. I regrounded the amp, sanded paint and have the same noises. Rerouted rcas and it helped slightly but still static. The last recommendation i revieved is the noise s comming into the system from head units power or ground and thay i should ground the head unit to the chassis. Im grounded through the wire harness. Also there are random popping noise in the speakers such as when high beams are turned on or ABS is activated. Lastly, when turning off the vehicle there is sqeaking that goes through the speakers.
