Kicker comp r
Is it me or do anyone remember a couple years ago kicker had comp r 12s that was 800 watts rms a piece
Yes, but from what I've read, they had to change the rms to 500. Whether it was because people were smoking them out and warranty claims or what, not sure
If you punch it in google, bestbuy still has a link to them but when clicking on link it takes you to item no longer available.
Look at the search description for that same link and they have them spec'd for 800
Better subs out there anyways.
I got mine new in box, in a box for $50. I'm happy with it. I'm also nowhere near the caliber you guys are as far as knowledge or even the ability to tell the difference if I heard it, but for now it does what I ask.
354
891
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
charleslatrelle
Nashville TN
Austin175
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
