Single 10" in 03 f150 super crew
  • 4
berretta96
I'm wanting to add a sub to my truck. For ease of installation and budget, I've been looking at an enclosure that fits under the rear seat. The one I think I want is .92 cubic ft sealed. The box is kind of shallow btw. I have a few amps around so i can power it anywhere between 150-750 rms (real power). I'd like to stay under $200 on the sub.
http://www.soundoffaudio.com/single-sub-box-2001-2003-ford-f-150-supercrew/
Sent from my 2PYB2 using Tapatalk
---------- Post added at 10:56 PM ---------- Previous post was at 10:55 PM ----------
http://www.caraudiobargain.com/b-stock-sundown-audio-sd-3-10-500-watt-sd-series/
---------- Post added at 10:57 PM ---------- Previous post was at 10:56 PM ----------
Only shallow sub I would go. Underhung design great sealed. Needs little clearance.
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
322
582
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
806
berretta96
berretta96
boise, ID
berretta96
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
