Need Amp
Alright guys , so i have between this 2 amps both used " will ve pushing 2 Ab xfls mechman 240 and 2 batteries all 0 gauge .
1- ct sounds 2200 for 300$
2- soundqubed 2200 for 330$
which one and why . will be running at 1 ohm daily music bump while driving to places thats all .
I think it was primarily larger boards, but ive heard of bad smaller ones too. 1400s even.
I did deplorable things to my old aq3500. As have all my other old teamates who ran them. Their qc is obviously better than ct
Wanting to buy a 2000 plus rms amp " Used " but in good condition ' need to push my 2 American Bass Xfls 200-320- the most i can spend thanks
How about a C2 Audio Recon 2.4 Amp? Used for $325 shipped? Don't have the bass knob but it does 2400 watts at 1 ohm at 12.8volts. Does over 3k at 14.4v
393
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
868
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Alejandro14
Alejandro14
Texas
P.smith1050
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
