No audio from radio
  • 4
  • Participants list
I know its not the radio I thought it was so I replaced it and it's still doin the same thing I took the driver door panel off and the door tweeter was broke n just hanging by the harness so I disconnected it and it and it worked fine them I installed my subs and it started doing it again
When does it work? Does it work when you're on radio input, but not on others? If so, you have you need to connect your remote wire where your antenna wire is connected to get the OEM amplifier integrated and turning on.
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
112
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
553
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
615
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
Bassmaniac
Bassmaniac
Baltimore ,md
nismos14
    Mar 28, 2024
    Mar 28, 2024
