High vs low power handling subs
  • 6
DylanBeatz
Wisconsin
Do higher power handling subs not get as loud on little power as lower power handling subs?
My kicker cvr 12" is actually pretty loud on only 300rms. Would a sub that can handle 3000rms be just as loud as my cvr on 300rms or are they generally less receptive to small power since they can handle so much?
That was, I believe, a serious answer. If you are under powering a sub, one typically puts it in a larger enclosure. The main problem one has with an amp that is, how you say, too 'small', one typically tries to make the amp do more than it's designed to. As long as you know and understand about clipping, and that the amp is not made to produce outside of its parameters, you should be fine dude.
Should be a no brainer there. the answer is hell yeah.
300 watts on a sub compared to some people on here isn't all that loud. That power is used on tweets/mids while subs getting 100's of watts.
If your thinking about picking up a good quality 3k amp, make sure you got the electrical to support it.
depends on the sub. Heard a pair of TC sounds 5200s doing a moderate hairtrick on less than 200 watts to each. Box plays the biggest role next to the sub's actual efficiency depending on the actual engineering specs of the sub.
There's also T line enclosures where you only need a few hundred watts and you'll get crazy loud.
Cool, so you are saying that there are certain subs out there that can handle 3000rms but at the same time will be just as loud as my kicker on only 300rms? And I'm not talking about different enclosures, just standard ported box. If so that's awesome and sounds insane. I feel like my kicker would be so loud if I could give it exactly 10 times the power it's seeing now and it would handle it.
The 5200s were in a normal ported tuned to 28hz. Was gnarly as fk. Will sh*t on any cvr setup lol. Imagine if it got a full 5k rms.
****! Lol awesome, you remember how many subs and what size by chance?
1w1m is an accurate way to measure it's output, kinda.. lol
Reguardless if the woofer has a rms of 3kw or 300 if the 1w1m are the same then output will be the same all other things being equal.. the 1w1m is a actual measurment of 1watt of electrical input to an acoustic output! Which is measured in db. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
The kinda Is because the input signal is 1khz. So naturally the driver with the higher bl and lower mass will always be more efficent.
What they don't tell you is you need to measure at 40-50 hz to be more accurate..
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
410
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
You need to set the high pass filter for your 6.5" speakers. I wouldn't run anything lower than 80hz. 100hz would be alot safer. Adding a...
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
432
DylanBeatz
DylanBeatz
Wisconsin
Jeffdachef
just call me KeV
    Apr 19, 2024
just call me KeV
    Apr 19, 2024
