My 2dr Blazer Build.... the saga continues...
Joebobclark
Your Moms New Boyfriend
Sssssooooooo...... Back from the dead here!
Its been awhile, and my other post is closed, so you can catch up here
Its happening!
0604161359_HDR by Joebobclark, on Flickr
4th order wall, 4 cubes sealed, 11.5 cubes ported, changeable ports...
Picked up a Bora Saw guide, thing is awesome for quickly ripping down full sheets of wood with just a circular saw...
0604161531_HDR by Joebobclark, on Flickr
Dual layer on all walls and baffles....
0605161406_HDR by Joebobclark, on Flickr
0609161841_HDR by Joebobclark, on Flickr
0609161841a_HDR by Joebobclark, on Flickr
Upper back wall will be removable for access to subs...
0610161739_HDR by Joebobclark, on Flickr
0613161832b_HDR by Joebobclark, on Flickr
0614161829_HDR by Joebobclark, on Flickr
Built 2 ports to start with, one is tuned 44-45 hz and the other 52-53 hz. 200 sqin of port area on each...
0610161739a_HDR by Joebobclark, on Flickr
0613161832_HDR by Joebobclark, on Flickr
0613161832a_HDR by Joebobclark, on Flickr
Rounded over most of the edges and Kreg screw holes will be filled and sanded, then the whole port will be painted..
It wont slide into the Blazer, so I will begin building it inside the truck tomorrow.... More pics to follow!
Looks real good man. Can't wait to see the final product. Keep up the good work //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Thanks //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
---------- Post added at 08:57 PM ---------- Previous post was at 08:56 PM ----------
Not alot of time to work on it tonight but got the front loading wall on!
0621161918a_HDR by Joebobclark, on Flickr
0621161918_HDR by Joebobclark, on Flickr
Working hard last and today....
Painted the port in white for now, just to seal the wood. Plan to paint the inside of the box white with LED's in the future, but wanted to get it playing for a show/comp tomorrow..
0624161913_HDR by Joebobclark, on Flickr
Little test fit before I went all in..
0624161913a_HDR by Joebobclark, on Flickr
Wired up, ready for subs...
0625161637_HDR by Joebobclark, on Flickr
Subs in, ready to close it up...
0625161820_HDR by Joebobclark, on Flickr
All closed up, port in, ready to go!
0625161844_HDR by Joebobclark, on Flickr
0625161843_HDR by Joebobclark, on Flickr
And as of 9pm tonight, its alive! Tuned by ear, very conservatively, it sounds great.
0625162110_HDR by Joebobclark, on Flickr
Best joint strength. What's the woofers and amps?
Thanks.
Subs are custom, Adire Brahma motors with Sundown frames and PSi soft parts.
Amps for now will be my SS Rubicons with a PPI DSP-88R. I have two 4 channels that are paint matched to the 2500. Gonna build a little amp rack in the back. Right now I have a PPI 5 channel in, that I was using as a small temp amp.
Hope to get it trimmed out in the next few weeks and get the SS 4ch's and DSP installed so I can tune it and see what it can really do.
Put some time into the truck this weekend...
Little snakeskin vinyl for the front, to match my headliner (I redid it from the blue skulls to a black snakeskin when I started doing copper color in the truck instead of blue lol) and made some side filler/braces to seal up the wall.
0723162149_HDR by Joebobclark, on Flickr
Painted the inside of the box white and added some leds inside (will post pics once they are powered up). Painted the sides of the box and braces black so you cant see them through the windows..
0724161856_HDR by Joebobclark, on Flickr
Made my front trim panels, still need to make the lower one to go around the 8's, but that one is going to be a pain in the @ss...
0724161857_HDR by Joebobclark, on Flickr
Trim panels carpeted up and installed, port painted a copper/orange color...
0724162031 by Joebobclark, on Flickr
And started on an amp rack idea... not sure if I like it or not yet, will see...
0724162136 by Joebobclark, on Flickr
Thanks for looking!
Registered here just to ask you a few questions..
Im currently walling my 95 2 door blazer, same type deal, a slide in 4th order with a trim panel.
Trying to use 2 evil 18's... Max size I can squeeze is 37.25" width, 29" height, and 39" deep, that leaves me something like 20 cubes before displacement, 5, 13 and change ported with 252sq in port (half of cone area)
What are your demensions of this box before the trim panel?
Sounds about right...
Mine is 38" wide, 30.5" high and 29" deep external dimensions... It was supposed to be 32" high, but I couldn't fit it at 29" deep and have the front be where I wanted it. Im 6ft, and like to drive relaxed, so I set the wall back further to allow my seat where I want it since this is my daily driver. Mine wont slide in/out because of the height, built it in the truck.
It's doubled walled all around and double baffled, so internal after displacements leaves me right at 4 cu sealed and 11.5 cu ported. Easily could have gotten more airspace by building out over the wheel wells, or moving the front forward for more depth, just didn't really need it for my 2 15's. If you are going single walls with just bracing, should be able to get 5 sealed/13ish ported, I started with a bit over 20 cuft as well.
I will tell you I wish I had given these 15's a little more on the sealed side. Having no TSPs for them, except what I could pull from them with my DATS, I went a bit conservative. I think I would have gotten more lows with a little larger sealed section, FS I pulled from the subs are around 32hz, but I also am not planning to run a ton of power to them. If you are going to be giving the Evils rated or higher power, better to keep the sealed side smaller for control.
I built my ports at 200 sqin (20x10), tuned to 46-47 on the daily, and 53-54 for SPL. I haven't really played around with it yet, but I figured that would be my maximum port area and I could shrink it down if need. Metered the daily port, it was peaking at 36hz, did a 144.7 with a very conservative "by ear tune". Will have it back together tomorrow, and get it tuned with my o-scope. Hopefully, play around with it Saturday and see where my peaks are for both ports and get a meter on it at full power....
Looks dope dude.
Might be on the hunt for a Rubicon 4.600 amp. If you know of one f/s lmk...
Thanks.
I'll sell you this 4.600.... but it comes with the 4.500 and 2500, lol. I had them up for sale as a package at one point, Im going to need more than 2500 for these 15s, and I like all my equipment to match (i.e. why I painted all these) so they would have to go all together.
16
422
755
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
666
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
723
Joebobclark
Joebobclark
Milford, NH
Joebobclark
    Apr 13, 2024
    Apr 13, 2024
