Just got 2 jl 10w1v2 4 ohm Subwoofers for free need help
I just got these subs from a buddy of mine for free to put in my truck. I was wondering what would be a good box for these subs. I drive a 96 single cab ford so I'm going to need a truck style box. Just wondering if anyone can lead me in the right direction to the correct plans or if there are prefab boxes that work well with these. Thanks.
Whats the depth of the subs? Will they fit behind your seat? Youll have to go sealed thats forsure and since its a singlecab, prefab options are limited. Youll see the same dual 10" sub box everywhere.
For sealed they need around 0.7 each.
They're less than 5" deep so it shouldn't be that hard to find a box that will work. Figure out some dimensions you have to work with. Try not to go much below 0.7 cf. If you can fit something that's closer to 1.0 that could only help.
To port them you'd need 1+cf net per sub so probably close to 3cf total. I doubt you'd be able to come up with that kind of space.
When you random through your music library, you know you got your gear dialed in nicely.
18
Back in the late 90’s, I took my S-10 to Pigeon Forge Tn for the Mini Trucking nationals. The cops there were the worst that I ever seen. They...
Yeah, I'd give them a call. They might replace it. If they do, that is huge CS. I've never known of any mfg to replace an amp because of complete...
17
joey13091
joey13091
Washington
joey13091
    Apr 13, 2024
    Apr 13, 2024
