wiring
Car audio is made with more strands and thus is far more flexible but is generally twice the price. Get welding wire from here. Same stuff. Slightly less flexible.
ROYAL EXCELENE WELDING CABLE
Sent from my SGH-T999 using Tapatalk
If he needs a wiring kit he'll need the other stuff anyways so no real reason to go for welding wire. The amount you'll save is so minimal too.
Knu is great and so is JL, Knu is less expensive but some places have JL 8ga kits for really good prices! However I have used both both are good and I would recommend knu //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif just if you get there kit order better RCA's, the RCA's that come in there kits are meh at best. IMO not worth running, but there upper line RCA's are much better
Signal flow should be HU to DSP to amps. You would lose the ability to EQ and time align the sub with the DSP unit if you bypassed the DSP.
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
357
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
310
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
387
Bobby Light
Tennille, GA.
Newellzie
Chris Gerrish
    Apr 25, 2024
vlusardi
    Apr 24, 2024
