Weird rattle but not blown for shure
  • 2
XxAndreaxX
spain
Hi, was doing some experiment with my enclosure, to fix air escape.
due the sundown is so heavy, I was experimenting with the other sub. I didn't want to change amplifier, too much effort, so I connected the 4ohm 110W sub to the audiopipe 1500 amp. I know its rated 1500W at 1ohm, but at 4 ohms, it should barely give 540W.
did some tests at very low volume, never brought the sub to distorsion, never could smell fried copper, but after tests, when I push down the coil, it makes some weird cracking sound. I really don't thing its fried, because the first sign of even premature overheat, is hear some coil friction when pushing it from only one corner of the cone, but in this case the sound comes when pushing down from the center.
Could be some dirt fell inbetween coil and magnet?? that would be the first time something like that happens to me.
was looking at the coil with a headlight and color was perfect and very clean.
WTF
Audiopipe'S nasty power. Probably burnt it up
why? I never exceeded power, and the coil never touches the magnet, its more like a clicking sound, maybe its the spider. I must admit, in my tests, I brought excursion to the limit, is it possible that the spider gave up??
no way, the woofer starts clicking when excursion gets high. its a mechanical sound for shure, but I can't identify where it comes from. I'm shure its not a deformed or blown coil, normally a blown coil makes distorsion at higher frequencies, I had the issue once.
Yeah, somebody goofed. It was supposed to last 5. I have seen speakers fail at the solder joint on the cone under the black glue. But you are...
8
Sometimes the sound gets a bit lower, then gets normal again, only listening to FM radio. It does not do this when streaming music via wired Apple...
so an update: basically i got my 2nd car which i just installed a car amp kit and routed all the wires so i thought to myself lets take this amp...
5
Error was fixed by soldering their connector on mine, mine wasn't color coded (e.g. red - switching power, yellow - constant power etc.) It was...
6
XxAndreaxX
spain
XxAndreaxX
Deepak Walia
    Apr 23, 2024
Random4thGuy
    Apr 23, 2024
Latest topics
